04-16-2025 12:19 PM
Hi the Canon EOS VR Utility is causing me the same problem that was reported on the Mac OS 15.2 version
I now have the same problem using Mac OS 15.4 and I have all the updated software that got pushed out this year. with the new Canon OS Utility from Jan 25 and Mar 25 .
The VR Utility software just freezes so if you have this problem and can revert back to OS 15.2 you might find it still works.
But for myself I'm stuck because my new machine came out with OS 15.4 installed and I don't know how to get back to an earlier version I hope Canon can do a quick update again, its probably the same problem that effected the 15.2 version Of Mac OS and Canon need to do another update to keep up with what they are doing which is a shame .
04-18-2025 05:35 PM
Hi Yapstam,
I'm sorry to hear you're having issues with the EOS VR Utility on your computer. To trouble shoot this we would need more information on what is happening for you. I see you mentioned it is the same as a previous issue, but things like freezing can happen for different reasons. So we would need information on what is specifically happening in your case.
Is the software freezing when you first open it up, or does it only freeze when you try to use a specific function in the software? Is this happening with every file in the software? Do any error messages show on the computer when the software freezes and if there is an error message what does it say word for word?
04-18-2025 11:33 PM
Hi good Morning
05-07-2025 08:59 AM
Hi all
I think I may of found my problem I was recording with the canon R5c with the battery grip Bg10 with the new EP-6 batteries this allows me to record 8k raw Lt on the canon R5c with the firmware update would this mean I could only save to a max setting of 8k pro res LT and why I was not being able to save in the higher setting of pro res 422 and 422HQ and 4444. I will get a battery pack now and hopefully record to a higher setting and see what f that resolves my problem .
could you confirm if you think this is the case .
many thanks Scott
05-07-2025 05:34 PM
Hello Yapstam,
That is a great observation. It could likely affect how/what you're able to save.
