06-02-2019 08:05 PM - edited 06-02-2019 08:09 PM
Camera: Canon PowerShot SX620 HS
Canon Camera Connect App: Android 2.4.30.14 (build 1034) and iPad iOS 2.4.31.16 (build 1048)
After setting the Canon Camera Connect App to record location and taking pictures with my PowerShot, the GPS location info is successfully added to the pictures when I resync.
But, after that when I use Camera Connect to transfer the pictures from the Camera to my Galaxy S8 or iPad, I go to the picures on my Galaxy S8 or iPad and GPS location info is gone from the pictures.
This issue has been reported before on an older thread:
https://community.usa.canon.com/t5/Software/Camera-Connect-App-User-Guide/td-p/148802/page/9
Thanks to that thread, I found out I have to remove the SD card from the camera and use an SD card adapter to transfer the pictures directly to my Galaxy S8 and iPad. This is not as convenient as transferring the pictures directly with the Camera Connect App, but at least the GPS location info is preverved when transferring the pictures with an SD card adapter.
This has been a known issue, when will this issue be fixed?
11-14-2019 06:29 PM
02-02-2020 10:01 AM
Hi!
This is working for JPGs but if I try and transfer RAW images across from my EOS R to my iPad, the location info is still removed, even if I have it set to not delete location data.
So I have the choice of trasfering images with the location data or RAW images, but not both. Is this expected?
