06-02-2019 08:05 PM - edited 06-02-2019 08:09 PM
Camera: Canon PowerShot SX620 HS
Canon Camera Connect App: Android 2.4.30.14 (build 1034) and iPad iOS 2.4.31.16 (build 1048)
After setting the Canon Camera Connect App to record location and taking pictures with my PowerShot, the GPS location info is successfully added to the pictures when I resync.
But, after that when I use Camera Connect to transfer the pictures from the Camera to my Galaxy S8 or iPad, I go to the picures on my Galaxy S8 or iPad and GPS location info is gone from the pictures.
This issue has been reported before on an older thread:
https://community.usa.canon.com/t5/Software/Camera-Connect-App-User-Guide/td-p/148802/page/9
Thanks to that thread, I found out I have to remove the SD card from the camera and use an SD card adapter to transfer the pictures directly to my Galaxy S8 and iPad. This is not as convenient as transferring the pictures directly with the Camera Connect App, but at least the GPS location info is preverved when transferring the pictures with an SD card adapter.
This has been a known issue, when will this issue be fixed?
11-12-2019 12:31 PM
I would have thought that in that instance the setting would be redundant and not matter.
11-12-2019 07:02 PM
@Dbruce wrote:I would have thought that in that instance the setting would be redundant and not matter.
Not finding a file would throw a software exception, so the software developer would have to write additiona code to "handle" the error. Firmware has hard storage space limits. Writing additional code to handle unnecessary exceptions takes away from memory space to implement features. Besides, it is extremely bad form to allow users to throw exceptions.
11-14-2019 10:10 AM
Rather technical response but if I understand your thread correctly, you are suggesting that defaulting to not including location data is necessary because there would be problems with defaulting to including location info if there is no location to include, and to rectify this would require additional code that could in and of itself, cause additional issues. While an intersting perspective, i'm afraid that with all due respect, I cannot accept that reasoning. And, in fact, would go so far as to suggest that the required coding is already built into the app.
Why do I say this? I have an SL2 that, by default, does not collect or include location data. Based on your reasoning, if I attempt to transfer pictures with the 'include location info' turned on I would run into problems. This is not the case at all. I have no problem whatsoever transferring pictures without location info regardless whether that app is set to include these data or not.
Further, the SL2 can include location info if connected to my iPhone via bluetooth and the CanonConnect app meaning that on the camera I can have a mix of pictures with location info as well as those without. Again, if your reasoning is correct, I would be required to do a two-step transfer; first for the pictures without location info with the 'include' turned off, and second with the 'include' turned on for those pictures with location info. This is not the case as the app currently allows me to transfer both types of picture without problem regardless of the setting (including location info turned on or off). The only difference is that when turned off, the location info is not transferred.
As such, at least for the SL2, the redundancy I spoke of is already built into the app and my orginial question remains valid but unanswered.
Cheers!!
11-14-2019 10:53 AM
11-14-2019 10:58 AM
@Waddizzle wrote:
You do not have accept it. You have to live with it. Exception handling is expensive, both in memory space and time.
I find your rationale that it is already built in amusing. Yes, there’s code to handle just one type of exception. You are suggesting that they should add another exception handler.
It will never happen. The development team is probably broken up by now, and has moved on to newer procducts.
I'm not suggesting any such thing. The 'exception' you are referring to has already been addressed as per my comment.
11-14-2019 11:57 AM
11-14-2019 12:21 PM
11-14-2019 12:29 PM
11-14-2019 01:29 PM
11-14-2019 05:26 PM
