06-20-2026 08:23 AM
I have cycled through a few editors the past few years and come back to DPP4. While software like Lightroom and Darktable can all find the lens im using, DPP4 says Lens Data: Not Available. I have installed the lens data for the lenses in question (EF 24-105 F3.5-5.6 IS STM, EF 50mm f1.4 USM, EF 70-200 F4L USM) and this has not resolved the issue.
Is there any way i can select which lens is used manually?
06-27-2026 05:43 PM
Can you post one of the RAW files to One Drive Dropbox or similar file sharing site.
06-27-2026 06:05 PM
We're you running the EOS Utility v2?
There is no reason not to upgrade the firmware on your 5D at this point. You're not going to brick anything using a smaller card. The camera will continue to support the smaller cards with the added ability to support up to 2TB.
V1.1.1 adds
1. It now supports high-capacity CF cards.
2. It allows the latest lens names to be recorded in the Exif information of images taken.
3. It adds lenses that are compatible with the Digital Photo Professional 3.2 lens aberration correction function.
Number two might solve your problem? I would give it a go.
06-27-2026 07:55 PM
I get that error if I execute the program and no camera is connected. When you connect the camera to the computer is it recognized as a device?
08-16-2026 02:00 AM
I've just run into the same thing. In my case I have just upgraded from several 30D (on firmware 1.0.4) to a R5mkii. Previously the lens correction on DPP3 for the 30D was fine. But wouldn't work on DPP4 until I upgraded the frimware to 1.0.6 (which I think was released in 2008.... anyway, bygones).
So this means any photos I take from now on using a 30D will be fine, but all my old cr2 files there is no way of using DPP4 - so I need to keep both DPP3 and DPP4 for legacy purposes. Obviously, If I'd realised I should have upped the firmware decades ago. But then again, seems there is minimal reason that DPP4 couldn't be made to work (by canon) given the data needed is there in the CR2 file.
08-16-2026 09:55 AM
Thanks for posting. This is helpful info. There are still folks out there using older gear.
