Cannon EOS Rebel T6 not connecting to iPhone
NicoleBix
I’ve downloaded pictures for years using the wifi function from the phone. For some reason, my iPhone will no longer connect to the camera.  The last time I did this was probably a month ago. I have an iPhone 11 with iOS 16.4. The camera is a rebel EOS (5?).
The Canon Connect App is offered by Canon for free.
Canon Camera Connect on the App Store (apple.com)
As mentioned previously, you may want to start over, resetting the Camera's network settings, and remove the saved profile for the camera in the App.
Remove Camera ProfileRemove Camera ProfileTap hamburger menu top rightTap hamburger menu top right
9 REPLIES 9
SamanthaW
Moderator
Moderator
Hi Nicole!
You should be able to see the specific camera model on the front, top right corner!
EOS Rebel T6
stevet1
Nicole,
Have you changed phones in the meantime?
If not, your best bet would probably be to delete the wifi settings from both your camera and your phone and starting over.
Have you been using Canon Camera Connect to handle your downloads in the past?
Steve Thomas
I’m using the same phone for a few years now. Up until now my phone has connected to the wifi of the camera fine. It may fuss a bit because there is no internet connection, but there wasn’t an issue.
Nicole,
I'm sorry I can't be of more help. I don't know why it would just up and quit working.
What app on your phone have you been using in the past?
Perhaps if you re-installed the app?
An app I have been using is called Camera Connect and Control. You can use it either wired or wirelessly. At the time I got it, it was free to use for 3 days, and then $9.99 to purchase. I understand the price has gone up since then.
Steve Thomas
Thanks for your advice. I’m using the cannon camera connect. I’ve deleted and reinstalled the app and will try to reset the wifi today. If that doesn’t work I guess I’ll try a different app and see if that works better.
NicoleBix
So erasing the disabling the wifi on the camera and then enabling it (and resetting network connections on the phone) seems to have done the trick. When re-enabling the wifi, I had to re-setup the iPhone and camera connection on both the phone and camera.
Thats correct.  Its like "starting from scratch".
Glad it worked.
