Hoods for Older Lenses
j_fox
Hi everyone,
I was hoping someone could help me verify which hoods I need for a few of my lenses. I know there are aftermarket or filter thread hoods available, but I prefer to keep everything original. Below is a list of the lenses I don't have a hood for, and the corresponding (if known) model number I was able to find. Can anyone fill in the blanks and/or confirm the information I have is correct?
  1. 28mm f/2.8 (non-USM / non-IS - 1987 model) -- Unknown
  2. 28-80mm f/3.5-5.6 USM (Mark I w/ metal mount - 1991 model) -- Unknown
  3. 35-135mm f/4-5.6 USM -- EW-62 or ET-62?
  4. 100-300mm f/4.5-5.6 USM -- ET-65?
Thank you in advance!
MikeSowsun
The old Arc Form Drive EF 28mm f/2.8 and EF 35mm f/2 both use the EW-65. The ES-65 is only a little longer, and would probably also work. Especially if you are using it on a crop camera.
The EF 28-80mm f/3.5-5.6 USM (Mark I metal mount) uses the EW-68B, but the EW-68A is nearly identical, and will also fit.
The EF 35-135mm f/4-5.6 USM uses the EW-62
The EF 70-210mm  USM and EF 100-300mm USM are nearly identical and both use the ET-65
Mike Sowsun
3 REPLIES 3
deebatman316
EF 28mm F/2.8 AFD: EW-65II
EF 35-135mm F/4-5.6 USM: EW-62
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Trinity, EF 85mm F/1.8 USM
Retired Gear: EOS 40D, EF 50mm F/1.8 STM & EF 70-210mm F/4
MikeSowsun
Mike Sowsun
Hi Mike,
Wow, thank you so much for the detailed information! All of my lenses are usually fitted to my 5D Classic, but I sometimes use a Rebel XT as well.
