EOS 5D Mark IV CFexpress Type B card compatibility
Mahrukh_
I accidentally purchased a CF EXPRESS Type B card for my 5D mark IV. Is there any sort of adapter which i can use to use the CF EXPRESS TYPE B card in my Canon 5D Mark IV.
3 REPLIES 3
I have a feeling you're well out of luck there.  CFExpress cards are a different shape, size, and use a completely different bus -- PCIe as opposed to parallel ATA.
I don't think it would even be physically possible to make an adapter which fits inside the camera and takes a CFExpress B card, unless it was completely sticking out of the camera.
This is the big difference between CF and SD -- SD has kept compatibility over many generations at the cost of performance; whereas CF sacrifices compatibility to get the latest, fastest bus (PCIe now).
None.  Not an option.  If unopened you can likely return.
ManishCanon
Not at All...No any option of Converter or Adapter to solved your issue.
