09-10-2023 03:06 AM - last edited on 09-12-2023 08:32 AM by Danny
Hi, I just bought the Canon LP-E6NH 7.4V batteries, and they are supposed to be compatible with the R5. But they're too big for my camera. Can someone comment on this? Are they in a case? If so, how do I slide them out? I'm not the most mechanical person in the world. Thanks so much!
09-10-2023 12:31 PM
09-10-2023 03:35 AM
The battery comes in a tan plastic case from which they pop out. You have to take the LP-E6NH battery out of the case or it will definitely not fit in your camera's battery compartment.
09-10-2023 12:19 PM
Hi, I took the tan plastic case off and the battery still doesn't fit. I am at a loss. It is way bigger than the battery compartment of my EOS R5.
09-10-2023 12:26 PM
Can you share photos of the battery with us? From multiple angles? That would be super helpful! 😊
09-10-2023 01:20 PM
Here are the pictures
09-10-2023 12:28 PM
Unfortunately, I'm going to have to return the battery. It says right on the order this is supposed to be compatible with the EOS R5, and it will not fit in the battery compartment. Buyer beware of the BM Premium Camer Power and Care Bundle Canon LP-E6NH 7.4V 2130mAH Lithium Ion batteries if you're trying to fit them in the EOS R5.
09-10-2023 12:31 PM
OK, so these aren't Genuine Canon batteries. ☑️
09-10-2023 12:48 PM
Where did you purchase from? For Canon batteries, only purchase directly from Canon, or from Authorized Canon Resellers. Otherwise you risk counterfeit products that could end up damaging your equipment.
09-10-2023 12:54 PM
I purchased them from Amazon. Canon BM-LPE6NH appears on the battery.
09-10-2023 12:57 PM
Thanks for the list! I will buy from one of these resellers.
