01-06-2023
12:35 PM
12:44 PM
my Canon 80D cannot take pictures with a C1-type shutter cable. When I click the remote shutter button, it does focus adjustments (like a half-press effect) but never releases the shutter.
I've tried with multiple cables and to be sure it's less to do with the cable, I got a brand new one from Edelkrone at BH, yet no luck.
I've made a recording at https://youtube.com/shorts/aVofGN7vbnA?feature=share
Any idea how to fix this? Let me know. Thanks!
Camera: Canon 80D
Shutter Release Cable:
Remote shutter:
[Commercial links removed per forum policy and replaced with screenshots to facilitate discussion.]
01-06-2023 01:55 PM
Are you sure camera is achieving focus? Set lens at MF and see what happens.
01-06-2023 02:00 PM
Thanks for your response. The video I posted was made with manual focus. When in manual focus, it just removes some details from display but do not trigger shutter, just like doing a half press.
01-06-2023 02:14 PM
I just looked at the video again. It says ni card in camera. You probably have that protection set in the Menu.
01-06-2023 02:35 PM
No, I've not enabled that protection, verified in the settings. Btw, I could trigger from shutter button on camera.
01-06-2023 02:39 PM
Since the camera shutter button works it looks like all is pointing towards either a defective remote or some other setting on the remote that needs to be changed.
01-06-2023 04:05 PM
Yea, looks like some settings got messed up. I did reset all settings though, yet the same behavior. I've used different cables, different remotes nothing helps.
It did work a couple of weeks back when I kept reinserting cable but the same trick isn't helping anymore.
I thought it must be something to do with the cable, so got brand new from Edelkrone but is not helping either.
07-03-2023 11:54 PM
I had this or a similar problem shooting the fireworks the other night. I am not sure if you resolved your issue, but mine was I had the mirror lockup selected. Turn that off, and it works better. It solved my problem anyways.
https://support.usa.canon.com/kb/index?page=content&id=ART164644
07-04-2023 03:01 AM - edited 07-04-2023 03:07 AM
Have you tried the Canon RS-60E3 Remote Switch? That's the wired remote release specified for the 80D. B&H sells them for about $22.
There also is the Canon RC-6 Wireless Remote Control. This is a small and works up to around 15 feet away. I don't have an 80D, but other cameras that use this wireless have their sensor on the front. So I think this unit is primarily intended for "self-portraits".
A third possibility is the Canon TC-80N3, which is an intervalometer that can be used for time lapse, or for extra long exposures. It also can serve as a simple wired remote release. It's considerably more expensive than either of the above.
WHOOPS! Never mind. I just checked and he TC-80N3 is not compatible with the 80D. There are some similar 3rd party intervalometers such as the Vello Shutterboss II.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
07-04-2023 07:45 PM
The TC-80N3 Remote is VERY MUCH compatible with the 80D and other cameras with a single-pin socket. It just takes getting a Canon RA-E3 adapter. I have one and can use my TC-80N3 with all of my cameras.
It's available from Canon, and dealers(B&H, Adorama, Amazon, etc.). It's cheaper from dealers.
