08-09-2024 10:12 AM - edited 08-09-2024 10:35 AM
Hello all !
I hope you are all doing well..
what would be the advantages or disadvantages of having an EF25 II extension tube connected to an ef 75-300
Im a little curious to learn more about these add ons and recommend settings..if any
Use will be for military aviation at air shows ..
cheers !
Alexander
08-09-2024 01:58 PM
I think you are confusing an extension tube, which is used in macro photography, with a tele-converter, which is used on telephoto lenses to give them more reach or longer focal length.
I'm sure you can attach the extension tube to the 75-300 but I'm not sure what benefit it would serve as I've never used one on a tele lens. But they do restrict focus on my macro lenses. As for putting a teleconverter on the 75-300, Canon doesn't make a tele-con that will work on that lens. You may be able to find a 3rd party tele-con, but I wouldn't go there. Your best bet is to get a lens with a longer focal length like the EF 100-400mm L mark II or one of the 150-600mm lenses by Tamron or Sigma
Newton
08-09-2024 01:58 PM
Newton
08-09-2024 02:01 PM
Thanks my friend .. sigma will be the way I go …
08-09-2024 02:21 PM
You are welcome! I think you will be happy with the siggy, particularly for air shows.
Newton
08-09-2024 02:30 PM
Taken with my 150-600 tamron
08-09-2024 02:33 PM - edited 08-09-2024 02:33 PM
After all the vids I just watched on that’s siggy.. it’s going to be the solution I need… I’ll just throw my smaller lens on to photograph the aircraft on display
but once the demo aircraft start takin to the air … it’s siggy time
especially the blue angels
