02-14-2014 10:53 AM
when I record using the XLR Channel 1 on my XA10, then import the video clip into video editing programs, the playback level is very low or not there at all when I play the DVD on my home intertainment system, using my Pioneer AV Receiver. Is there another setting on the XA10 where the playback level can be adjusted?
02-17-2014 07:18 AM
Hi DDoyle!
Thanks for posting.
When you play the video back on the camcorder both with and without headphones connected, does the audio level sound normal?
02-17-2014 11:31 AM
Volume sounds okay with headphones, but very low without headphones, even with the slider all the way up. One thing which is likely a factor is that I had to turn on Mic Attenuation when using XLR recording, due to sound distortion in higher DB ranges. A third factor is that the extremely low audio level is most pronounced when I play the video back using my Pioneer VSX-520 AV Tuner amp (using HDMI cable from DVD player to tuner). The sound track from the XA10 XLR input is too low on all listening modes except "advance surround". If I bypass the tuner, there is no problem, but I prefer not to have to do that, since all other DVD audio, such as movie DVDs, and CD tracks added to videos, have normal audio volume.
02-17-2014 11:52 AM
photo of the XLR settings on my XA10 -- note that mic ATT is on, and that CH1 appears to have input incorrectly adjusted too low? Sound playback thru headphones is a bit low, and very low thru camera speakers (AV). Real problem is playing through my Pioneer VSX-520 AV tuner.
