ZR30MC No Signal on CRT Tv
Sossboy
When I went to plug in my Camcorder into my CRT (Sansui COM311ADB)  through the yellow AV cable, I checked line 1 & 2 and I had no signal. I'm not sure what to do in order to get a signal on the tv as I already have read the manual and made sure that the AV setting on my camera was to set to AV. If this matters, the AV port is super loose on the camcorder.
1 REPLY 1
Nick2020
Hi Sossboy,
Thanks for checking in with us. Make sure that you are using the STV-250M cable that came with the camcorder. Then go into the camcorder's menu and navigate to AV/PHONES and make sure that it is set to AV.
Put the camcorder in the playback mode and then toggle through the various inputs on your TV.
