12-18-2024 07:17 PM - edited 12-18-2024 07:18 PM
Hi All, I just received my C80 and am learning it. I noticed something peculiar.
I am shooting in UHD 3840x2160 @ 59.94 fps. I have the camera connected to a Blackmagic Hyperdeck via SDI which is configured to accept this signal.
When recording footage through the C80, the Hyperdeck receives signal as expected.
However, if I playback the recorded footage from the C80, the Hyperdeck no longer detects signal via SDI.
In comparison, I have a Sony FX6 which I use similarly. And the Hyperdeck receives signal from the FX6 in both recording and playback modes via SDI.
It seems, the C80 does not output UHD signal through SDI when in playback mode. I could not confirm this within the manual though. I also did not find an obvious setting to adjust this. Does anyone have experience to know if this is normal behavior?
12-18-2024 09:59 PM
I'm researching this. Thus far I see HD output over SDI, but a 12G SDI can do 4k 60p, so I probably haven't found it yet.
Are you running The latest firmware? 1.0.1.1 was released today.
Firmware Version 1.0.1.1 incorporates the following enhancements:
12-19-2024 03:49 AM
Unfortunately I can't test that scenario, as my only SDI sink is a 3G monitor. Both recording and playback show up on that monitor, as HD signals.
But I suspect you may be right -- on the C80, playback is not the same as normal viewing mode. For example, if you shoot Log, ViewAssist doesn't work in preview or playback modes, on any of the outputs -- LCD, SDI, or HDMI.
Sorry, I can't help with a fix. I'm hoping firmware updates will improve the playback modes.
12-19-2024 03:19 PM
Thank you Rick. Unfortunately the FW update did not help. I guess this is just how the C80 works.
12-19-2024 03:21 PM
Thank you. Agreed, seems this is just how the C80 works. I will send an email to Canon to ask/request if UHD playback support is possible via future FW update.
12-19-2024 05:52 PM
You can do that on the Canon USA homepage. Look in the upper right hand corner, select [+]Feedback, then product.
