10-28-2020 03:00 PM
Hi!
If I set my XC-10 to HD, I can enable time code / trigger signal over HDMI to start my Atomos Ninja if I press the record button on camera. But if I set it to 4K, the time code / trigger - option is disabled / grayed out.
Why can I trigger my Atomos Ninja just if I set it to HD?
Thank you
Wolfgang
10-29-2020 02:23 AM
Ok... problem solved. Had to reset all settings, suddenly the HDMI time code can be set even in UHD. Don't know why, but it works now.
10-29-2020 02:23 AM
