Vixia HF R600 not recording
PuzzledPerson
I've had my camcorder for a couple months, but I haven't used it very heavily and there are no scratches/dents anywhere. Recently, I have discovered that when I try to record, the time stamp indicator thingy says "00:00" and doesn't go up. I have a Lexar 633X 128 GB memory card. It has been my only card and has recorded perfectly in the past. After the problem emerged I put all my remaining videos on my computer and wiped the memory. The problem persisted even though I had over 16 hours of available recording space. I also wiped any grime off the SD card and the card slot, so I believe it is something wih the camera.
p.s. Once I dropped it from about 2 feet off the ground, it still recorded afterwards, though.Robot Sad
2 REPLIES 2
IamintheUK
Rising Star
Rising Star
Have you tried re-formatting the card in the camcorder? If you re-formatted using your computer this would cause problems.
__________________________________________________________________________________________
EOS C100 mk2 with a Canon EF-S 18-135mm IS STM, and a Sigma EF mount 10mm-20mm EX DC HSM wide angle - Zoom H2Essential - Dell 8700 i7-4790 3.6Ghz, 24GB Ram, Win 10, Nvidia GTX 1060 6GB - DaVinci Resolve Studio 20.3 - Blackmagic Speed Editor - Presonus Faderport 1.
Richard
Hi PuzzledPerson,
Thank you for posting.
Your camcorder is not designed to accept memory cards using the UHS-I, UHS-II or UHS-III standards. Some such cards will have "UHS-I, UHS-II or UHS-III on them. Others will have a "1", "2" or "3" superimposed on a "U". While some of them are backwards-compatible, not all will work.
I recommmed checking with Lexar, for backward compatibility with the Speed Class 10 memory card standard.
