‎11-11-2023
07:44 AM
‎11-11-2023
08:27 AM
during recording on hfr800, the camera change from 24p to 29p by itself, making half the video uneditable.my go around was to output from the hdmi out directly into a switcher that recorded everything, which worked.the weird thing is when you looked at the footage in the camera, it read only 3 videos and played fine on the camera, however when downloading the 3 videos from the sd card to PC to edit the video there was 5 videos,to which 4 of them chnage frame rate on there own. Never saw anything like this, any idea why? use the same camera again and no issues.Im really puzzled and help would be appreciated.
‎11-11-2023 08:02 AM
Are you using dual slot recording? And for the main card, did you select a video quality of 35 Mbps? The User Manual states that 35 Mbps recordings will always be recorded at 60 frames per second*.
Manual also states on page 76 that dual recording makes use of a lower 4 Mbps bitrate for the other copy of the footage. Though I don't see details on if using 4 Mbps, would that be recording in a very specific frame frame.
* note that even though the manual references 60, 30 or 24 frames per second, it will actually be 59.94, 29.97 and 23.976 frames per second.
‎11-11-2023 08:23 AM
it always is set at 24P which I know is the 23.97. it’s never changed it’s my preferred frame rate.
‎11-19-2023 07:58 AM
someone suggested that there maybe a possible glitch in the camera,if the battery is low it may switch the frame rate to save power.I dont know,still waiting for answers
