05-15-2013 02:05 AM
HF S10 is not listed in the compatibility list for the WM-V1. But it seems like it has to work, you only have to plug it into the microphone jack. Think it will work?
05-20-2013 07:33 AM
Hi pkohlmil!
Thank you for posting about this. The WM-V1 should work great with the VIXIA HF S10 as well as many other models, as all it does is connect to the microphone jack.
05-20-2013 07:33 AM
Hi pkohlmil!
