05-25-2015 12:43 AM
Hi
is there a Canon utility that will join up the fragmented 2GB .MTS videos?
So much wasted time trying to join up frgments of video all with different overlaps.
Thanks for your help.
Rob
PS. I've actually just purchased my first Sony handicam because they don't have fragmented video like Canon FAT32 do.
What a relief. So fast to work with.
PSS. Disappointed that the new Canon Mini X I just purchased still cuts video into 2GB files. Why???
If I format the card outside the camera will it help?
05-25-2015 10:18 AM - edited 05-25-2015 08:39 PM
Sorry one more thing I don't get.
If I lay out my 2GB MTS fragments in Adobe Premier sometimes there is no overlay (several frames missing) so I can't join them up by hand. But a program like Povtube can join together 2GB fragments perfectly. Mystery??
Anyway still hoping Canon have a solution for this. I love my Canon camera's but as I deal with more and more HD video this I need an easy fast solution. All I want is MTS001+MTS002--> MTS00x -- Surely that should be fast to do.
05-28-2015 03:20 AM
05-28-2015
07:12 AM
09:21 AM
Stephen
Thanks for the reply Jane.
Going from MTS to another format requires hours of recompiling (eg. Joining 2 or more 2GB .MTS files to .mpg).
Good news I found a utility "tsMuxeR" http://www.videohelp.com/software/tsMuxeR
which can join .MTS files to .M2TS in seconds instead of hours.
But the question remains -- Why are current release Canon cameras still fragmenting video recordings into 2GB files and
what utilities do Canon provide or recommend to join files.
05-29-2015 01:59 AM - edited 05-29-2015 02:04 AM
They are infact AVCHD file with various mts clips inside i guess. AVCHD is widely used and can be read by some NLEs like FCP X natively. Can't seem to find an AVCHD ultilities from Canon so far.
06-13-2015 01:41 AM
I have a Canon Vixia HF G20 and it has the same 2GB limitation on file size. When I am ready to edit I copy the entire folder from the SD card to the computer. I use Adobe Premiere Pro CC 2014 to edit , I import the files and have found that I only need to put one clip (I use the first one) of the several into the timeline and it shows the entire event that was recorded. In other words it seems to "join" the files together so that I don't have to drag each individual clip into the timeline. The only time I have to add clips is when I have paused or stopped recording for various scenes. All that said, which may of no use at all, I'm not sure if it is the editing software or copying the entire folder that helps.
10-18-2018 01:59 AM
| i use Avdshare Video Converter to Join many MTS clips into one MTS file and convert the joined MTS to MP4, WMV, MOV, AVI, FLV, MKV, ASF, etc. |
01-07-2020 10:39 PM
Another method is to use iDealshare VideoGo to join avchd files into one with the following easy steps: Step 1: Drag and drop the avchd files to iDealshare VideoGo. Step 2: Click Merge button. Step 3 click Convert button.
01-10-2020 06:35 AM
