02-21-2016 12:44 PM
Specs say that if you choose 17Mbps, the frame rate should be 24p, but it shows 30p with no other options. How do you set the camcorder to 24p?
02-21-2016 10:53 PM
Do you have the camcorder set to cinema mode? Try looking at pages 82-85 of the manual - http://gdlp01.c-wss.com/gds/1/0300017441/01/hfr60-62-600-im-n-en.pdf
Also look on page 115. It appears as though this option (24 fps) is avaiable only when recording MP4 movies.
02-21-2016 10:53 PM
02-22-2016 02:34 AM
That did the trick! Thank you!
