File numbering HF R800
rhckm49
Enthusiast
I initalized an SD card and when I put it in the camera, the number that comes before the date does not reset. That is depite the number resetting on my G40 with the same SD card.
3 REPLIES 3
Mark35mmF2
Good morning,
It sounds like you may have the file numbering method set to continuous instead of reset. This is changed in your System Setup menu in the camcorder. You can find information on changing the file numbering setting on page 206 of the user manual (https://gdlp01.c-wss.com/gds/0/0300025910/03/vixiahfr80-82-800-im3-en.pdf)
While I am mentioning the R800 camera, why does it not shoot in AVCHD considering that previous models like the 700 do shoot in both MP4 and AVCHD?
Did you try initializing the card in the R800? Personally, I never use AVCHD. I want a higher bitrate than it can accommodate so always use MP4
__________________________________________________________________________________________
EOS C100 mk2 with a Canon EF-S 18-135mm IS STM, and a Sigma EF mount 10mm-20mm EX DC HSM wide angle - Zoom H2Essential - Dell 8700 i7-4790 3.6Ghz, 24GB Ram, Win 10, Nvidia GTX 1060 6GB - DaVinci Resolve Studio 20.3 - Blackmagic Speed Editor - Presonus Faderport 1.
