06-30-2021 03:44 AM
I am trying to record the output of my XF405 camcorder to an external monitor Blackmagic 12G in ProRes 3840x2160 50p via an HDMI lead. In the camera I select External Rec Only HDMI and in Recording Setup I select 3840x2160 50p, but when I go to Display Setup, the Output Terminal setting is grayed out. What is wrong?
06-30-2021 09:15 PM - edited 06-30-2021 09:20 PM
I haven't used the camcorder but consulting the on-line user manual - presumably it is grayed out because there is nothing to set i.e. you have chosen the video configuration for external recording (3840 x 2160, 50p) which is only output as 8bit 4:2:0 from the HDMI OUT terminal?
07-01-2021 12:02 AM
Thanks for the reply. I am using the HDMI OUT terminal. I set everything exactly as it says in the manual. The only difference is the manual specifies (for External Rec Only) 3840x2160 YCC 4:2:0 8-bit but my camera shows it as 3840x2160 YCbCr 4:2:0 8-bit
07-01-2021 12:26 AM
YCC is just an abbreviation for YCbCr
07-01-2021 06:49 AM
I've solved it. The monitor wasn't set to HDMI. Now it works great. Strangely though the Output Terminal setting in the camera is still grayed out.
07-01-2021 11:56 AM - edited 07-01-2021 12:14 PM
@extravogon wrote:I've solved it. The monitor wasn't set to HDMI. Now it works great.
There you go.
@extravogon wrote:Strangely though the Output Terminal setting in the camera is still grayed out.
Why strangely ? I explained that above. The only reason a menu item would NOT be grayed out is if there are setting options and there are none in this case because you have already selected 3840 x 2160, 50p as the video configuration for external recording and there is only one output option for that - 3840 x 2160, YCbCr/YCC, 4:2:0, 8 bit on the HDMI OUT terminal.
The [Display Setup] > [Output Status] menu option will confirm the video and audio configuration of the output signal. Page 153.
07-02-2021 10:15 AM
OK, and thanks for your help.
