07-11-2019 04:10 PM
I have a question about the AVCHD format mode on my Vixia HF R700. I normally use the MP4 mode set to the 35Mbps setting.
My question is about the difference between the two formats.
I took a short video using both formats. When I checked the Properties I found that both of them came up with 1920X1080.
Is there still a benefit of using one format over the other?
I also have a question about the two formats. I can not see the AVCHD file in Windows 7 Explorer. I can only see it when I open it up in Windows Photo Gallery.
I also have a quesition on transferring videos. I have never been able to transfer from the camera to any of my computers.
When I attach the USB cable the computers, they do not recognize the camera. The only way I can transfer the videos is to use an external card reader.
Thanks, Lloyd
07-11-2019 05:55 PM
I, too have the choice between formats. With the higher bitrate I get better resolution with MP4 35Mbps so never use AVCHD. Both use the h264 codec, it's just being put into different types of container. The AVCHD spec only allows bitrates up to 28Mbps.
I always use a separate card reader to transfer files, which in my case is built in to my computer.
07-11-2019 05:55 PM
07-11-2019 06:43 PM
Thanks for your reply. I'll just stick with MP4. It sure is a lot easier to work with!
Best regards,
Lloyd
07-12-2019 01:14 PM
There seems to be a few small differences in what settings you can or can't make between AVCHD and MP4. But the only major differences I've found is that AVCHD files can be easily copied to Blue-Ray Discs. And MP4 files are much easier to open in most video players and more readily edited with most software.
07-12-2019 04:05 PM
Thanks for your reply. Since most of my work is burning to DVD's I'll just stick with MP4.
Best regards,
Lloyd
