05-13-2015 05:13 PM
I am going to filming some projects using a Canon XA10 and a Canon XA20. All of the projects are going to be burned to DVD's, yet there is also the possibility for web use.
I understand that the Canon XA10 only films in the AVCHD codec, while the Canon XA20 provides the option to film in both the mp4 codec and AVCHD codec. For the purposes mentioned above, should I shoot using the AVCHD codec on both cameras, or could I use AVCHD on the Canon XA10, the mp4 on the Canon XA20 ( to save storage space/render time), and still receive quality results? I will be editing with Premiere from the Adobe Creative Cloud. Thank you for any assistance you can provide.
05-15-2015 06:45 PM
Hello Clare27,
You could use either option that you mention with successful results. You'd need to take into consideration your editing requirements and the overall footage requirements when choosing. We would suggest however, that you pick one format and stick with it- as this will make editing much easier.
05-15-2015 06:45 PM
Hello Clare27,
05-20-2015 11:26 AM
Hi Tim,
Thank you for yor response. I greatly appreciate it 🙂
