Reply
New Contributor
Re: Another computer is using the printer
Solution for MX922 Series:
Make sure you cancel all pending printing jobs.
On the printer:
1. Press Menu
2. Choose Set Up
3. Choose Device Setting
4. Choose LAN Setting
5. Choose Other Settings
6. Choose WSD Setting
7. Choose Timeout Setting
8. Choose 10 minutes
That should solve your problems. Trust me, this drove me nuts for months. and you are welcome Smiley Happy
New Contributor
[ Edited ]
Thanks  @1Reticent, that fixed it for me Smiley Happy
(Couldn't see how to quote your reply)
New Contributor
WOW, THANK YOU!!
New Contributor
Not sure if this is posted already but pretty simple fix!
1)Hold down the WINDOWS KEY on your keyboard and then tap the 'R' key
2)Type services.msc and then click OK
3)Scroll down the list until you see a service called 'Print Spooler'.
4)Right-click 'Print Spooler' and then choose 'Stop' by left-clicking it
5)Right-click 'Print Spooler' again and then choose 'Start' by left-clicking it
New Contributor
When I try to print on my Canon MG5560 I keep getting the following message....
Another computer is using the printer.
The following status is the usage status of that computer.
New Contributor
Clear the print spooer to fix the problem:
Run command prompt as administrator.
Enter the following commands:
  net stop spooler.
  net start spooler
  Exit
New Contributor
This is a driver issue.
Need to go and delete the controle panel and delete all physical printers not being used including the canon.
No reinstall the printer. you may need to go to Canons web site and downlload and install the drivers to make it all work properly. Worked first time without any problems.
Good Luck,
David
Highlighted
New Contributor
Thank you! Thank you! It was driving me crazy and such a quick fix. Thanks again.
powered by Lithium
