12-11-2022 11:39 PM
We, our university, bought TASCAM CA-XLR2D-C for Canon R5 C. It does not work. The adapter does not get power from the camera and also does not work with batteries. When connected to the camera, the yellow light with the camera symbol lights up for a short time, but then turns off after a few seconds. The camera displays the error message below: "Currently, the accessory cannot be used"
Tried everything firmware update, reboot, etc, but no results.
Unfortunately, all this happens at the beginning of a shoot in a foreign country. What to do?
08-29-2023 12:01 AM
Hi Rick,
I don't have batteries installed. Mine still has "crunchy" (unusable) audio until I turn off the camera and turn it back on. Every time that I go into the menu on the camera this problem shows up and I have to cycle power on the camera. The cause is simply going into into the menu the effect is me needing to tell the Canon and Tascam engineers that they can do better.
09-05-2023 08:17 AM
This happened to me. The unit was sent back to Tascam for repair, I got it back and it happened again straight away. Both times it happened when I plugged in a 2nd XLR cable....
09-05-2023 08:18 AM
This has happened to me twice now, after having it repaired the first time I am at a loss about what to do...
09-05-2023 08:19 AM
It's happened to me twice. Still no resolution
01-03-2024 06:06 PM
I bought my R5c and Tascam unit brand new in Oct 2022. Have been shooting video and recording audio flawlessly since then. Today, on a shoot, I have begun to experience these same issues. After reading other peoples' experience, it does not make me excited to go into further troubleshooting. What a joke.
01-04-2024 08:42 AM
After maybe 8 or 9 calls to Canon and Tascam, a couple of product repair fails, and maybe a dozen hours wasted, I eventually gave up. Infuriating that they still sell this defective product. After about a year of using an external recorder, I recently bought the "RODE Wireless PRO 2-Person Clip-On Wireless Microphone System/Recorder with Lavaliers" which has a 1/8 inch output and seems like it'll deliver what I need. Good luck!
01-04-2024 02:28 PM
Welcome to the club of upset users. Your story is very much like mine. I received both the R5c and Tascam around Feb-Mar of 2022 and everything was fine until that December on a shoot. Luckily, I had a Zoom recorder on hand after troubleshooting failed. I didn't use the Tascam for 3-4 months, but now I'm back to using it again. I've updated both the R5c and Tascam firmware and honestly, I don't know how much that helped or not I think it's more in the setup procedure. Now I use the Tascam battery pack to power the unit instead of using the R5c and I make sure the Tascam is attached to the R5c and powered on before I turn on the R5c. I haven't had any problems since.
01-04-2024 04:22 PM
@Texcoepus,
Appreciate that you are keeping this dialog current. I'm afraid that Tascam has an issue with this device. It's an approved device by the OEM (Canon) but they don't have any control or responsibility what Tascam is producing. I think holding Tascam's feet to the fire is what's appropriate. However, we all have our limits of what we want or should endure. I'd be less enthusiastic if my device had gone back for repair or replacement and it only worked once or didn't work when it came back. People do eventually move on. Especially if the gear results in loss of revenue. I hope that people will be taken care of by Tascam if they choose to pursue that avenue.
01-12-2025 07:54 AM
I'd like to chime in since I found this thread looking to resolve the exact same problem with my unit.
My Tascam unit lit up when I turned my R5C on but after a few seconds it powered down and my R5C reported something like "Currently, this device can't be used".
After updating the firmware of my Tascam (no luck) and reading a lot about people sending the unit in for service that made no difference, I did a lot of testing and found out this:
If you are using a mic that does not need +48V (Phantom power), but you have your INPUT 1 or 2 set at +48V, then the Tascam unit disconnects and the camera reports "Currently this device can't be used".
After I turned off +48V (set the INPUT 1 to Mic) and powered it all up again my unit worked perfectly fine.
This might be common knowledge in this group, but it wasn't for me so I thought I mention it. I'm often using Sennheiser G3/G4 units connected to my other Canon cams, leaving the XLR phantom power enabled on the cams with no problems. On this Tascam unit it matters a lot.
Hope this helps someone.
Best,
Petter
