06-27-2021 08:31 PM
Hi all,
I'm close to getting the GR-V1 grip to work with Canon C70 and wanted to share some findings and get some advice!
I pre-ordered the C70 with the intent of using on my shoulder on occasion and having on-grip controls. It would be a massive flaw if this camera were unable to do so, as that means it simply can't compete as a documentary camera.
I'd love anyone's assistance helping me find a cable/adapter to work from the 3.5mm Canon C handgrips to the 2.5mm remote terminal. I'm fairly certain this will work based on the below findings.
FS5 and FS7 Grips
Connected via LANC cable, both of these handles are recognized by the camera and the joystick functions with up/down/left/right and select. The record and other buttons do not work, which is expected because they are mapped differently. But it shows that the remote link's capable of receiving multiple signals.
C100/C300 Grips
Do not work, because audio cables don't provide either enough power or consistent signal. (Or maybe I just can't plug them in all the way)
Cameo Gear Grip
This thing is ugly and buttons are a bit flimsy but it works via hirose to lanc cable. I've tested this as well. Iris and button mapping work. These are somewhat hard to find as they are entering EOL.
GR-V1
This, of course is the natural choice to use. I've purchased it and am looking to connect it to the C70. Any help in selecting a cable (or cable+adapter) to make this happen?!
Attached are a few photos
The Canon 3.5mm grip connection on the GR-V1 (C-series grip). The C70 only has 2.5mm remote in.
This cameo gear grip works but it's really not intuitive and no longer supported by manufacturer.
(Yes, excuse the tripod ball.)
Lastly here are some of the cables I have tried. I was advised to use 3.5mm to 2.5mm audio adapters but they either do not fir or do not work with the GR-V1
Any thoughts on where to find a cable or combination of cables to get the GR-V1 grip working on c70? Thanks all!
11-18-2021 02:33 AM
It's been a while, but I solved it!!!
The Canon C70 can be used with an assignable handgrip. It turns out it was all in the menu settings.
First update the handle to the latest firmware.
Then, re-connect the handle and under "assignable buttons" tab in the MENU, toggle to the number 3, and you should see a sub-menu titled "REMOTE A". That's your handle. You'll be able to assign those 4 buttons there.
IT WORKS with these grips so far:
Cameogear Cameogrip
FS5 / FS7 Grips (which feel really nice!)
DOES NOT YET WORK WITH
C100/C300/GR-V1 Grips. But someone let me know!
Hope this helps the one other person in the world trying to use the C70 on their shoulder.
01-11-2022 04:36 PM - edited 01-11-2022 04:37 PM
-Best bet for the FS5 grip is either ebay or a rental shop with old gear. If you have an existing FS5 serial number, there is a chance Sony will send you one and charge you for it.
-I used the cameogrip with the latest OS. The software works fine out the box. The build quality is partially metal. It's solid for 10+ pounds, but requires some tightening. I've found it loosens a bit during heavy use.
-I was able to toggle AF, dial exposure, and run rec with the FS5 grip, the Cameogrip works for ISO or aperture with joystick plus a couple basic functions (peaking/zebras). I chose IRIS and manually adjusted aperture when necessary.
I also have one button set to ND, which helps, but it's unidirectional.
03-22-2022 08:31 AM
Hey! Curious if you were able to figure anything out with your FS7 grip?
05-24-2022 03:48 PM
THANK YOU!!!
Can't believe there aren't millions of c70 shooters trying to work this out.
So, looking at the handle to buy, do you think any lanc trigger handle would work? Like those wooden ones from smallrig for example.
Ideally want iris and start stop, am I stuck with the flimsy cameo?
I have a C100... could raid for spare parts if needs be
05-25-2022 01:04 AM
Heyas I have a smallrig handle with lanc that works. I think most should work without modification.
05-25-2022 02:25 AM
Thank you for the response!
ok so looks like Sony handles or the cameo. I guess you didn’t manage with the GRv1?
06-04-2022 11:17 AM
Thanks for sharing all this info. Very helpful. Firstly, I cannot believe there is not more on this on the internet, or even more/easier solutions to this with the C70. Even from Canon. So in the spirit of sharing...
I just have just bought the CameoGrip solution and bottom line is it works for me. I'll tell you for why. So Iris, yes no worries, record start/stop, and a couple of assignable buttons which all LANC interface with the C70 fine.
Now there was one issue when I received it - assigning autofocus only resulted in a pulse so was effectively useless. (and true, no moveable focus point control. Yet.) But when I contacted CameoGear about this they were right on top of it, immediately.
Jesse created a new custom version of the software so I could assign a continuous signal whilst pressed to a button, and hey presto. Auto focus = works like a charm.
OK, the unit is on the slightly flimsily built side and I'm no fan of the '70's chrome look, but this thing works, and the company behind it will respond to requests. Assigning the focus point control might not be impossible. But as I see it it'd replace the iris. So still tricky.
02-20-2023 05:45 AM
The LANC for C200 involves a (vital) 4'th connection not by the 3-part pin out of the 3.5 jack but via a 'socket-connection' circumfering the very base of the 3.5 jack.
Hence a std. 3.5 -> 2.5 adapter will not work for full compatibility w. Canon GR-V1 Grip.
03-22-2022 08:47 AM
Hey there, yes it works for some things, enough for me on the gimbal.
Fs7 grip - Stop/Start works, joystick works to move the focus box around, one custom button works (button 4) which I set to ‘function’ so can scroll through WB, ISO, Aperture, Angle and use joystick to set if needed.
Nothing else works (no other buttons can be assigned) and the traditional aperture toggle wheel shuts down the camera if you use it (also doesn’t work anyway for aperture) so taped over it. Apart from that works fine for stop/start, moving focus box and one assignable button.
Not sure if the fs5 grip works any better, don’t have one to try.
The cameogrip works with a few more assignable buttons 2 or 3 from memory and the aperture can be controlled by the joystick. But cannot control/move the focus box around.
05-25-2022 01:06 AM
Same experience, but with the FS5 handle, did not experience any accidental shutdowns. That may be specific to settings/FS7 grip. Accepting this as solution, ty all.
06-19-2022 07:29 PM
Does the iris dial work on the FS5 grip to change exposure?
great work too mate!
03-22-2022 09:27 AM
Thanks for the quick reply.
Using the joystick for the focus box seems like a solid win. Shame about the aperture toggle, but better than nothing!
I'll have to hunt one down.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
