10-14-2018 10:18 PM
This is probably a novice question, but I'm still learning the ins and outs of my speedlites. I currently have a wedding reception set up with two 600EX-RT on the dance floor and one on my camera as the master. Is it possible to have either a speedlite or trigger on my second shooter's camera as well to trigger those same speedlites?
Thank you!!
10-15-2018 02:18 PM
Yes, an additional 600EX-RT, 430EX III-RT or ST-E3-RT on your second shooter's camera can act as an additional transmitter for the same two off camera speedlites.
10-15-2018 02:18 PM
10-15-2018 06:10 PM
@PLee wrote:Yes, an additional 600EX-RT, 430EX III-RT or ST-E3-RT on your second shooter's camera can act as an additional transmitter for the same two off camera speedlites.
There may be some logistic issues, though. Most of the time, your second shooter will probably not be standing next to you. And if the lights are positioned properly for your location, tey may not be positioned properly for his/hers.
