02-09-2024
11:54 AM
12:27 PM
I’m really struggling to get my #Speedlite Transmitter ST-E3-RT to connect consistently. I’ve checked channels and ID. My transmitter says “sender” instead of “master”. Does that mean the same thing? If not, how do I change this setting?
02-09-2024 12:25 PM
If the link light on the ST-E3-RT and your Speedlite are both green then it's possibly a camera setting that is prevent the flash from firing.
The EOS R6 cannot trigger a flash when the shutter mode is set to electronic. You'll find this setting on the SHOOT6 menu. it should be set to either Elec. 1st-curtain electronic or mechanical.
Secondly check SHOOT2 menu, at the bottom of the page is External Speedlite Control, select that and make sure the Flash firing is set to Enable.
If both of these are ok, then it might be down to the mode on the transmitter and the group your Speedlite is set to.
If the ST-E3-RT shows ETTL or M or Multi on the top let corner of its display then make sure your flash is set to one of the groups A, B or C.
If the ST-E3-RT shows Gr on the top left then check that the group your flash is part of is set to actually fire. In Gr (group) mode, you can switch individual groups off so they don't fire.
02-09-2024 12:07 PM
What camera?
02-09-2024 12:10 PM
Thanks for joining the conversation, Jjwalz! We've changed the terminology used to reflect the relationship between Speedlite devices to "Sender" and "Receiver." Hope that clears it up!
02-09-2024 12:12 PM
R6
02-09-2024 12:13 PM
So “sender” is the same thing as “master”. Any tips on why the transmitter isn’t working properly? It shows a link to the flash but doesn’t fire with the shutter.
02-09-2024 12:25 PM
02-09-2024 10:45 PM
Thank you so much for your help! I learned the shutter mode was not correct. Now it is working great!
02-15-2024 09:31 AM - edited 02-15-2024 09:37 AM
Are you experiencing “ Link Drop”. This where you fire a couple images and then lose Connectivity in Radio Mode. Your Transmitter “Link” light will still be Green, however Off Camera Flashes will be Red. Not the way the system was designed.
Canon claims interference without identifying known “Interference”…. thus no solution to once reliable on location system to now a “Crap Shoot”…
And yes “ Trouble Shoot” from A-Z and sent in to CPS for service that was supposed to be performed, and not, and still “ Link Drop” in many, many locations.
