01-02-2024
09:14 PM
11:32 AM
I have a off camera flash that I can't get to work any suggestions
01-03-2024 11:15 AM
I'll ask one last time for details. Now that we know you're using it on-camera, please provide full details of your camera settings related to flash along with what mode you have the flash in (Manual, ETTL, etc.)
01-03-2024 11:17 AM
If you have the flash physically connected to the camera's hot shoe, it is ON camera. Only when you have the flash not connected to the hot shoe is it considered OFF camera. And off-camera can be controlled in one of many ways to include a sync cable, built-in flash to be an optical trigger, master flash in the hot shoe to be a trigger (optical or radio), or a dedicated radio trigger in the hot shoe such as an ST-E3-RT.
01-03-2024 11:21 AM
Yes sir its in
Flash firing Enable
ETTL balance Standard
Ettf ll meter Avernge
Contin Flash ctril E-TTL each shot
Slow sunchro 1/200A-1/60
Shutter Mode Mechanical
ISO 200
F/5.6
1/200
01-03-2024 11:29 AM
@miketerndrup wrote:It's a off camera flash instead of a in camera flash
OK, understand.
That is generally called "External Flash" since it is external to the camera. Could be in hot shoe, connected via cable or connected wirelessly.
Didn't see a response to question relative to test button. If you press the test button on flash does it fire?
Do you have access to another camera?
Just trying to separate a flash unit problem from a camera problem.
01-03-2024 11:31 AM
it only light up half the room when I test it
01-03-2024 11:32 AM
I just have the flash
01-03-2024 11:42 AM
@miketerndrup wrote:it only light up half the room when I test it
I don't understand what that means, but since it fires when you press Test it sounds like a camera or camera compatibility issue.
Since that is an older flash unit perhaps you should register your product (if you haven't already done so) on the Canon support site and then request Canon support.
01-03-2024 11:48 AM
I have it register
01-03-2024 11:56 AM
Give Canon a call then at 1-800-OK- CANON
01-03-2024 12:04 PM
Guy I believe I found out the issues please accepted my apologies
