10-18-2021 02:21 PM
I use my Speedlite in manual mode, on camera, for wedding reception candids. I noticed that I will get some great exposures and then about 5 or 6 shots later the image is blown out with no changes to any camera or flash settings and shot from similar distances. Any suggestions?
10-18-2021 02:24 PM
Are you sure the flash is in manual mode? How about your camera? Is it in manual mode as well? I'm wondering if say auto ISO is kicking in on occasion?
10-18-2021 02:36 PM
@Annette1 wrote:I use my Speedlite in manual mode, on camera, for wedding reception candids. I noticed that I will get some great exposures and then about 5 or 6 shots later the image is blown out with no changes to any camera or flash settings and shot from similar distances. Any suggestions?
Can you post some examples?
Are you using bounce flash or direct flash?
Are you using some kind of a modifier?
10-18-2021 02:38 PM
I am using all manual settings both on my flash and camera. ISO is in manual as well.
10-18-2021 02:38 PM
I'm using direct flash, no modifier. I will post some samples.
10-18-2021 03:01 PM
10-18-2021 03:02 PM
10-18-2021 03:08 PM - edited 10-18-2021 03:09 PM
The distances look different. What is the focal length used in each photo? Can you provide the EXIF data for each photo?
10-18-2021 03:30 PM
10-18-2021 03:31 PM
