Speedlite 270EX compatibility with EOS R50 with the Multi-Function adapter
vkbkbl123
I have a Canon Speedlite 270EX flash. Will it work with the Canon R50 camera coupled with the Multi-Function Shoe Adapter AD-E1?
p4pictures
Yes with the AD-E1 adapter you can use the old 270EX with your EOS R50.
However I cannot recall if the 270EX supports the flash menu functions that your EOS R50 provides. If it does not then you will need to make changes to the 270EX settings with the buttons on the flash itself.
Brian
10 REPLIES 10
p4pictures
Brian
The 270EX was the first entry level speedlite to support the in camera flash menu. The older 220EX did not support it as it was released in 1996. The 270EX only can be controlled from the camera menu. There aren’t on flash controls other than the power switch.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Thanks for helping out with the specifics, I couldn't recall that specific model's capabilities.
Brian
The newer entry level flashes are dependent on the camera menu to control settings. Using an older camera you cannot change the speedlite’s settings. There’s no way to do so on the speedlite itself. This is a different incompatibility that older speedlites such as the 220EX has. It has just a power switch and HSS/ FP Flash switch. 2nd Curtain Sync, FEC & AF Assist Beam firing is controlled from the camera body. Older cameras can’t fire an Intermittent AF Assist Beam. This requires updated hardware in the camera body. Cameras which support the in camera flash menu already have the updated hardware. Thus for older cameras I recommend an older speedlite such as the 430EX II. Which will work on both pre-2007 DSLRs and DSLRs with in camera flash menu support. This is because there is an LCD screen to make changes directly on the speedlite.
-Demetrius
vkbkbl123
I got the Canon AD-E1 adapter for my Canon R50 and my Canon 270EX works with the adapter. Thank you for your help. Trying it out and learning to use it now
DrTarandeepkaur
Is there any ring flash available which is compatible with the EOS R50?
@DrTarandeepkaur No not directly. You’ll need to use the AD-E1 hot shoe adapter. Canon makes the MR-14EX II MT-26EX-RT Macro flashes. They also used to make the MR-14EX (Classic/ OG) & MT-24EX Macro flashes these can be found on the used market today. They have been discontinued.
-Demetrius
Thanks for your reply ,can u please tell any other options for ring flash? preferably cost effective .
The EOS R50 doesn’t play nice with 3rd Party flashes.
-Demetrius
