ST-e3-rt Trigger with 430 ex  iii-rt and  a 600ex
canonhead65
Hi Hope someone can help I ma using the ST-e3-rt Trigger with 430 ex  iii-rt and  a 600ex, when i firen the trigger the 430 fire around a secound after the 600. I have turned off all groups except those that i am using as someone had previously suggested. The issue is the same when i fire from the camera or by using the test button. I am fairly new to this system so appologies if this is somthing obvious. I have previously used the same set up with no issues. any help would be greatly appreciated
3 REPLIES 3
kvbarkley
You should start your own topic, but does it happen when you use the 430 by itself?
Sorry yes, but couldn't see how to start a new topic, and yes it does the same when fired on its own from he RT
I started a new topic for you. ☺
