06-29-2021
05:26 PM
08:13 AM
Stephen
Hi Hope someone can help I ma using the ST-e3-rt Trigger with 430 ex iii-rt and a 600ex, when i firen the trigger the 430 fire around a secound after the 600. I have turned off all groups except those that i am using as someone had previously suggested. The issue is the same when i fire from the camera or by using the test button. I am fairly new to this system so appologies if this is somthing obvious. I have previously used the same set up with no issues. any help would be greatly appreciated
06-29-2021 07:59 PM
You should start your own topic, but does it happen when you use the 430 by itself?
06-30-2021 02:45 AM
Sorry yes, but couldn't see how to start a new topic, and yes it does the same when fired on its own from he RT
06-30-2021 08:12 AM
I started a new topic for you. ☺
