01-18-2023 07:18 AM
I recently purchased a Canon G1X III. I like to use bounce flash for horizontal and vertical shots. I have the 430EX which I could use. However the G1X III is such a tiny camera, the flash looks a little out of place. Is there an alternative more compact flash available that can swivel horizontally and vertically for bounce flash?
Kind Regards
Chris
01-18-2023 08:02 AM - edited 01-18-2023 08:08 AM
El-100 should work for you.
It's tiny, I have pics of it on an M50 on the product page reviews.
01-18-2023 07:21 AM
Look into 270EX.
01-18-2023 07:32 AM
John, thank you for your reply. Had a quick look. It's compact and can do bounce flash for panoramic shots, which is great. Shame it can't swivel the other way for vertical shots. But there may be little else to choose from.
Kind regards
Chris
01-18-2023 09:56 AM
Thank you. I will also check out the EL-100.
Kind regards
Chris
