Godox XPro C Trigger Not Firing from EOS RP Shutter Button
jakeamzy
I’m using a Godox XPro C trigger connected to an AD200 Pro speedlite, with my EOS RP. Despite the trigger successfully communicating with the speedlite (I can make it flash by manually pressing the trigger) I can’t get my flash to work when I press the shutter on the RP.
The trigger is being registered by the camera (there’s a little lightning icon that appears when I connect it), but still it won’t flash. What could be going on?
Firmware seems to be up to date. Same channel, same group, no ids set, etc.
1 REPLY 1
deebatman316
Is the camera set to mechanical shutter. If so your speedlite is INCOMPATIBLE.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
