05-09-2025
02:10 AM
01:56 PM
Never have used a flash or have done a headshot.
Hello all,
05-09-2025 07:34 AM
Bottom line is you'll need to practice, practice, practice. This is true for any skill.
Start simple: use a single light (be it the available light, or a single flash)
In terms of a light meter... For years, I went without one, but now find it increases my efficiency quite a bit for what I do. I use light setups with up to five lights (soon six), so it's much easier to dial in lighting ratios of individual lights, then lower the output of all lights at the end to get the desired starting exposure. I say starting exposure since per ones vision, you can always further adjust the lights to taste.
05-09-2025 06:52 AM - edited 05-09-2025 07:08 AM
You can still get the job done even without a light meter as long as you can monitor the histogram or check the blown out highlights (enable highlight alert in image playback settings).
2 lights and a scrim is workable, but you didn't mention light stands, so positioning your off-camera lights might be a challenge.
If I were in your shoes, I'd try
(A)
Rembrandt lighting for the main light, bounce off the scrim for the fill light, then use the 2nd flash to illuminate the background, or
(B)
Shoot through the scrim for soft Rembrandt lighting for the main light, then use the 2nd flash as rim/hair light.
Regardless of which setup you eventually go for, try these with a tripod to take self-portraits of yourself so you can figure out the positioning and flash power output before you shoot your client.
If you're expecting to do this regularly in the future, I suggest aiming for at least 3 lights, 1 light stand for each, and at least 1 modifier to soften your main light.
A scrim will soften the light just fine esp. for full-body portraits, but you may also want to consider a softbox with grid for control and ease of use.
05-09-2025 07:34 AM
05-09-2025 01:29 PM
Thank you so much! Yes I do have light stands and a tripod with a remote.
