04-13-2025
08:15 AM
09:32 AM
Stephen
I am trying to find an adapter that matches my Canon mr-14ex ii ring flash with Sigma 105mm f/2.8 macro lens (which has a 62mm thread).
Macrolite adapter are not available in this size, are there any other options for me?
I've been sold a 62 to 67 step up ring and a 62 to 58 step down ring, which both obviously don't work.
It has to be a step down as the ring flash is smaller in diamater than the lens, but I'm not sure which one to get. Appreciate the help!
Link to Flash: Macro Ring Lite MR 14EX II
Link to Lens: Sigma AF 105mm f2.8 EX DG OS HSM Macro (Canon) Ø62mm [Removed link per Community Guidelines]
04-13-2025 08:21 AM
Correct me if I'm wrong, but if I put a 62 to 58 step down ring on, then get a macrolite 58C adapter, will that work? Any easier ways with only one ring/adapter?
04-13-2025 10:17 AM
Shot of going to a machine shop and having them make you a custom adapter, then probably the best method is the 62 to 58 step down adapter then the Canon macrolite adapter 58C.
04-15-2025 12:00 AM
What body is the lens on? If it's a crop-sensor, a 62-58 stepdown will be fine. The full image coming through the lens is cropped by the APS-C sensor anyway, so there's no coverage loss. And if you're doing macro close-up work, you aren't making use of the lens's full area of coverage even on a full-frame body.
04-19-2025 08:45 PM
Perfect I'll see how this goes, thanks!
04-19-2025 08:46 PM
Good point. Canon r10, so shouldn't be an issue
04-25-2025 12:40 AM
Unfortunately, macrolite adapter 58c seems to be unavailable literally everywhere! Any potential sources you guys can think of? Based in Aus, but happy to purchase from anywhere.
