10-27-2013 07:02 PM
10-29-2013 12:57 PM
This seems odd. Normally my units "remember" if they were in a master or slave even between usage (e.g. if a unit was last used as a slave, powered off and put away... when I power up the flash (even a few days later) the flash "remembers" that it was last used as a slave and resumes that way.)
I had considered maybe a loose wire... so I set a unit as a radio slave, powered off and opened the battery door (just in case removing batteries causes a 'reset'), closed the door and powered it back on and it STILL remembered it's a slave.
I'd contact Canon. I can't think of a reason or condition that would cause a slave to reset spontaneously unless it's a defect.
10-30-2013 10:19 AM
