02-05-2016 04:02 AM
I accidently shot some RAW pics in 16.9 ratio. Using DPP I can see the whole frame and can, using 'angle clipping' ,remove the borders so it returns to the 'normal' ratio. However I cannot 'save as' ther image at this stage of the process. I know all the image is there as I can see it, but how do I save it without the borders? Thanks.
02-05-2016 04:44 AM
I tried with 6D and raw + jpg together with DPP3 and DPP4 and 16:9 and 1:1. All my picture came out in 3:2. Don´t know what happend there.
Anyway. Upload a raw file, for example via filedropper.com or via dropbox and I can take a look at it.
02-05-2016 08:07 AM
@PhotoMan01 wrote:I accidently shot some RAW pics in 16.9 ratio. Using DPP I can see the whole frame and can, using 'angle clipping' ,remove the borders so it returns to the 'normal' ratio. However I cannot 'save as' ther image at this stage of the process. I know all the image is there as I can see it, but how do I save it without the borders? Thanks.
Yes, if you shot RAW you can change the ratio back to 3X2. Using the trimming tool sellect either the 3X2 Aspect ration or Free and draw a 'cropping rectangle' that selects the whole photo. Then click OK on the trimming tool, and then from the main window choose File - Save or File - Save As to save it.
02-05-2016 04:11 PM
If you are using LiveView to focus a shot, take the camera out of LiveView before you snap the picture. Otherwise, you can get the 16:9 aspect ratio.
