01-09-2024
01:59 PM
02:04 PM
When will there be a driver for Sonoma?
We have an ImageFORMULA P-215II and a ImageFORMULA R10 that we're unable to use since we purchased new Macs.
01-18-2024 03:04 PM
The most up to date driver for the P-215II can be found HERE. As for the R10, this scanner is a plug an play scanner and does not have drivers.
If the scanner is not detected, try a different USB port or if connected to a laptop, make sure the laptop is connected to an outlet and not running off battery.
01-29-2024 09:05 AM
We are still getting a driver error with the R10. I was able to get the P-215II working on one computer but not on the computer we most need a scanner on. Any reason that would be?
01-30-2024 11:18 AM
It could be a security setting on the computer that is not allowing the R10 to open correctly when plugged in.
I will have to recommend that you call our support team at 1-800-423-2366, Monday - Friday, 9:00 AM - 8:00 PM EST (excluding holidays).
We look forward to hearing from you.
