imageFORMULA DR-C230: Capture Perfect 3.0, How to batch file a document to make each page new file
tateka
Does anyone know of any videos/proper instructions for the Canon DR-C230 with the Capture Perfect 3.0 software that shows how to properly batch file a document where each page is a new file? I have tried the user manual for both products and I just can't seem to figure it out. All it does is make one big file. Sometimes I need to scan over 20 single documents at a time and it's very time consuming to do it manually when the system has a batch file option. Any ideas?
2 REPLIES 2
JavaHouse
We're  using a different Canon scanner with the same problem. We are having no luck finding answers to the issue. Frustrating.
Thanks for joining the conversation!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
Friends and Family
