how direct LIDE 300 scanner output to a specific folder
wongskee
1 REPLY 1
Patrick
Hi wongskee,
To specify a folder, please open the IJ Scan Utility (or IJ Scan Utility Lite if using Mac)  and then click the Settings button in the lower right.
Click on the appropriate option on the left side.  For example, if you wish to change where scans are saved when using the "Photo" button, click on "Photo Scan" on the left side.
On the right, in the middle, you will see "Save In".  Click that drop down and then select your desired folder in which you wish to save the scans when using that button.
More information regarding Settings can be viewed using the appropriate link below:
Windows - IJ Scan Utility Screens > Settings Dialog Box
macOS - IJ Scan Utility Lite Screens > Settings Dialog Box
