05-01-2023 09:43 PM
I'm doing a fresh install on a new PC, and would like to know if the software/driver package for the LiDE 300 works also with the (earlier) LiDE 220 (I have one of each). Or if it's necessary to install both packages.
thanks!
Paul
05-03-2023 01:38 PM
The software will be the same for both but you will want to make sure you load each driver. Other than that, once both are installed, IJ Scan Utility will read both scanners.
05-03-2023 01:38 PM
