12-22-2022 05:39 PM
I'm looking for a definitive answer as to whether the Canon DR-6030C can be accesses using windows 10 Window Image Aquisition drivers. If so, is there a specific driver for the scanner that needs to be loaded?
I found DR-6030C_Driver_V.2.0.11508.7001SP6 which is labeled "ISIS / TWAIN / WIA Driver" and installed that, but the scanner still does not appear when I open windows (11) Fax and Scan (WFS.EXE). Is anyone aware of any issues, or how to verify that the scanner can be accessed through WIA?
Or does anyone know for a fact that the scanner is *not* WIA compliant?
I do not want to use TWAIN for my project if I can use WIA because the code is already written for WIA.
04-13-2023 08:49 AM
Any chance you've found a solution to this? I'm running into the same issue and have tried just about everything.
05-03-2023 02:30 PM
The only solution I have found is to use a 3rd party app in the Microsoft Store called AnyScan from better app. The issue revolves around the problem with Canon not conforming to the new software protocols for these scanners. PAIN IN BUTT, but the app does the job.
05-03-2023 02:31 PM
Microsoft Store -> Any Scan made by better app.
