Help for Capture Perfect 3.1: How to change from *.pdf to *.PDF
cujaysfan
Trying to figure this out a little blind and remotely for a field user.
Receiving *.pdf files
I think I need *.PDF for them to be compatible with my system.
Is there a way to change that flavor of PDF?  Conversion doesn't seem to work.
Is there an option to change file type or flavor somewhere?
Help!!!!  Thanks in advance!
2 REPLIES 2
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, let us know what model scanner or printer you are using?
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thanks for response!
Canon Image Formula Dr-M140 & use Capture Perfect 3.1
