10-18-2022 02:27 PM
Hi, I'm trying to connect my scanner via WPS. It does connect and recognize the device but when I try to type in the PIN, it says it's the wrong number. I look at the back of the scanner and it says security key: 00282647
On a side note, the documentation refers to some wireless connection tool but there's no tool installed or to download. I downloaded the TWAIN/WIA driver. There are some other software but nothing related to a wireless connection tool.
10-18-2022 02:43 PM
Please click the link below and keep selecting load more until Network Monitor and Connection Utility for Windows appears as a option to download.
10-18-2022 02:43 PM
10-29-2022 04:00 PM
thank you so much for the help! it turns out that I couldn't see that download because I had set it to Windows 11. It doesn't show up when you select Windows 11. I switched it to Windows 10 x64 and then I could see the option to download it. Luckily the software still works in Windows 11!
So my next issue is that I was hoping multiple computers could share the scanner. But the computer I set it up on works wirelessly. But the other computers can't use the scanner.
