Canoscan LiDe 400 will not print from ijscan utility
mangurian
Rising Star
If I press the Copy button on the scanner, a copy prints directly.
When I want multiple copies, the ijscan utility will not send to the printer.
I set up as shown and the hit "OK" and then "Auto."  Is that the right thing to do?
Patrick
Hi mangurian,
In Settings, please click COPY on the left side.
On the right side, increase the number next to "Number of copies" from 1 to your desired number of copies that you wish to make.
Once set, click OK.
To perform the copy function, press the COPY button on your scanner.
More information can be viewed here:
https://ij.manual.canon/ij/webmanual/ScanUtility/All/LiDE%20400/1.0/EN/SU/su-505.html
1 REPLY 1
Patrick
Hi mangurian,
Once set, click OK.
