CanoScan LiDE 70 Scanner software for Mac Catalina
7catsbarking
I have an old Canon scanner: Canoscan LiDE 70. Works great, except I just discovered that there is no compatible software for Catalina! Really need to scan some documents. Is there some generic scanning software that will control this scanner?
Any advice that doesn't involve buying a new scanner or reverting to the previous OS is appreciated.
Thanks.
17 REPLIES 17
Thank you for pursuing this. I looked for a driver on Canon site, and had to go all the way back to the Lion OS to find one. This driver would not install on Catalina. I also tried various earlier versions of Vuescan just in case, and, like the current version, none of them recognize my scanner.
Maybe the scanner really has died. Maybe I should plug it into other computers and try it.
I have a CanoSvan LIDE 90, this does not work under Catalina on my Mac Air. Is there a driver for the 90 series? Vuescan did not work for this.
wilmpaul
I have a CanoScan LIDE 90 that does not work with my Mac Air using Catalina OS. Are there any options for this situation?
Hi wilmpaul,
The CanoScan LiDE 90 is not supported with macOS v10.15 Catalina.  You are eligible for Canon's Upgrade Program.  This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system.  This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30PM ET).  If you would like to take part in this option, please call our Sales Department at (866) 443-8002 seven days a week, 8am to Midnight.  Let them know you have been working with technical support and the Canon Upgrade Program was offered.
smb12321
After much travail my scanner (Cano Lide 400 - $89) works with Catalina.  The agent checked my mac, tweaked a few things and said to erase anything relating to Canon, clear the Trash and restart.  I then downloaded the software but again nothing. He said change ports and it worked!  He was quite knowledgable and siad there were no "fixes" for older models.  I gave my perfectly fine Brother Scanner to my youngest son and bought a cheap one that is easy and reliable. Good Luck
Despite the claim that Vuescan is universal it does not work on many scanners.  My very common Brother scanner was not supported and the Vuescan guy said it was "hit or miss".
deus-ex-machina
I have your same problem.
I have a macbook pro mid 2014 with catalina and my scanner Canon Lide 70 not function.
Do you find a solution?
I never found a solution.
Holiday
