Need driver/SW for imageFORMULA P-215 scanner under macOS 10.15.4
accokeek_paul
Recently upgraded to macOS 10.15.4 and suddenly the Capture on Touch SW for the P215 which had qworked flawlessly under previous versions of macOS stopped working with a popup from the OS saying it was no longer compatible with the OS. Subsequent investigation revelas this is a 32bit versus 64bit issue with Catalina (macOS 10.15.4) only using 64bit applications and programs. Since I use this scanner with both my iMac and MacBook Air, I really need some kind of option to continue scanning. Any insight or assistance would be most welcome
1 REPLY 1
There is no Catalina (64bit) driver avaialble for the P215.  The High Sierra driver works in Mac OS through Mojave.
Apple decided to stop supporting 32bit software.
Two options:
Formula-P215II (Second gen)
https://www.usa.canon.com/internet/portal/us/home/support/details/scanners/document-scanner/imagefor...
Formula P-208II
Support is not discontinued intentionally, sometimes the hardware is not capable of the new OS architechture.  Canon will often offer a purchase discount towards a new product when a existing product goes out of software support.
