06-22-2020
10:57 PM
08:07 AM
I just received my new CanoScan LiDE 400 tonight. It installed with no problems, turned on with no problems...but now I'm constantly getting the error message
"Cannot communicate with scanner for these reasons:
-Scanner is turned off.
-USB Cable is disconnected.
Please check and try again.
Scanner driver will be closed.
Code: 2, 156, 33."
I have tried EVERY "fix it" I've found on Google and nothing is working. I've changed my computer to Power Saver battery option -- didn't work. Changed the suspension on the USB port...didn't work. Yes, I'm using a 3.0 USB port on a Dell Inspiron 17 5000 series laptop. I have Windows 10 and I think that's the #1 problem --- Windows 10.
I've installed two different drivers that's supposed to work... didn't. I've installed it via the CD-ROM, didn't work...uninstalled and re-installed via the website... didn't work. Nothing is working.
Should I just return the scanner and go with a different brand of product? I already have trouble with my Canon MG3500 series printer so.. I should have known better than to buy a Canon portable scanner.
08-07-2022 03:11 AM
I too got same problem. I visited local service center. He advised to format my PC. How could we format PC for scanner. I connected scanner to another LAPTOP. It worked good for 6 months. Now i am facing same with LAPTOP also. If I visit service center I am not sure if they will ask me to format my Laptop for proper working. I never expected such a failure product from a great brand like CANON.
09-11-2022 05:47 PM
I believe I found a workaround of the scan header position issue. As most of us here, my LIDE 400 randomly move the scan header to the back end position (where the USB port is) instead of to the front (where buttons are) after connection. It is quite random, nothing to do with which USB port is used from my laptop, or if the cover is open or closed, etc.
I read the post from someone from Canon Expert that the solution is toggle the Lock button several times and retry, giving some credit to this expert but that's not the solution (or it is only part of the solution). But this help me to understand this has something to do with the toggle.
After examining how the mechanic is designed, I understand the toggle is actually the source of the issue. It doesn't have the require precision to make the scan header "understand" that it is in "Unlocked" position.
So the workaround is quite simple (but still not very practical). when you connect the scanner to your computer, immediately push the toggle to the right side with force. This will ensure the scan header remain to the front side. And that's it.
09-14-2022 06:32 AM
i have tried everything and found a temporary fix, when the bar gets to the bottom I mash the auto scan button many times and it fixes the bar and the scanner goes back to normal but it goes back to be normal the next time I try to use it. now this fix has stopped working, this is planned obsolescence by canon. So we have to buy new scanners every few months. This is a firmware issue. That I am sure of. they have no way to rest its firmware.
06-20-2024 04:14 PM
@Chenxg0306
Thank you for your comment. I have been fiddling with the lock button, scanner open to see how the header was going on about up and down. Forcing the button to the right (really forcing, not sure pushing it hard once, but keep applying pressure on the button to the right) makes the header come back down. Stop applying pressure, it goes back up.
I do not know why it started behaving like this, the scanner is not even moved at all. It just happened suddenly ? I think it might be the case for most people who had this problem with this scanner. It must be a VERY poor design, since it also happened to the previous model.
Anyways, I want to thank you again, I was going crazy trying to find a fix! Nothing worked online!!
12-17-2024 06:50 AM
I have thrown mine away and ordered an Epson. I think this product is junk. It was temperamental when it did work and after spending 4 hours trying to make the stupid thing work I gave up.
My advice to anyone with this product who is having this problem and it's still under warranty is to try and get your money back on the basis that it's not fit for purpose.
Amazingly here in the UK they still sell it. I'm surprised because in my opinion it is not fit for the purpose in which it was intended or at least the one I got is not but it's out of warranty so I had no option.
I'm never buying another Canon product because of this.
I think if canon wanted to they could either do a firmware update or a repair process, but that costs money.
